Peel the plastic off the insulation?
Postby Scooter » Sun Jun 27, 2004 11:32 am
I'm using Dow R4 sheathing (3/4) throughout as insulation in my tear. Are ya supposed to peel that real thin layer of plastic off both sides? Probably doesnt make any difference, but thought I'd ask.
The RoadCamper the old teardrop
Scooter
Images: 69
Postby Guest » Sun Jun 27, 2004 5:15 pm
I've never used the Dow product...but the plastic may be a vapor barrier there to prevent the insulation from becomming water logged...be careful
Guest
Postby Ross Wade » Sun Jun 27, 2004 11:35 pm
Hey Scooter,
I used the same stuff in my tear. Floor, ceiling, walls and even had some left over to insulate an icebox I made. I left the vapor barrier on both sides. I didn't see any reason to remove it, however, I don't think it would matter much.
Hope this helps. Ross
Ross
Southern Appalachian Tearjerker Chapter Director
Ross Wade
Southern TearJerker
Images: 21
Postby Chip » Mon Jun 28, 2004 9:42 am
The thin skin on both sides of the insulation is for additional strength,,sort of surface tention,,if ya look close it usually has tiny holes in it,,it can be left on or pelled off,,no difference,,,if ya real bored start peeling,,
chip
54"x9'4" tear
4'x8' tear
Chip
Images: 49
Postby tdthinker » Thu Jul 01, 2004 12:20 am
What is the best insalation to use?
Ryan
tdthinker
