Jimbo wrote:I am thinking about using 1" aluminum angle 1/16 thick without trimming off one leg around the roof line of the td. With heating and hammer, is it reasonable to think this might work?
David Beckett wrote:My experience mirrors Geron's post, except I didn't use a form. I predrilled all holes, annealed it, and bent and pounded it into shape. I am not totally happy with it and may replace it but it works for now.
Good luck with yours.
Dave in Alaska
Jimbo wrote:Hmmmm, Well, if I rip a leg, how far should I rip it?
D. Tillery wrote:If you drill the holes before you bend it don't the holes get distorted?
I
Hope that helps,
D. Tillery
D. Tillery wrote:OK. What is your source for screw caps? I've seen some two piece plastic snap on type but there has to be something nicer out there.
D. Tillery
