fornesto wrote:I notched the sidewalls about 1/2" as you described and am very happy with the result. Things to consider are the thickness of the aluminum trim on top of the sidewall, around the hatch edges, the aluminum on the hatch, the 1/8"-1/4" plywood of the hatch itself and the weatherstrip. This does several things. First, it allows rain to run over the teardrop without finding an easy crack to enter (as you might with a flush hatch). Second, it allows the hatch to rest evenly along the entire length of the sidewall, which lets you have a tighter seal.
Resist the temptation to put overlapping l-metal trim along the outer edge because rain water travels sideways when you're driving and will actually be caught under the leg, as will air.
Say hey to the Ulster!
Users browsing this forum: Google [Bot] and 7 guests
