I've found a supplier for my torsion axle. But, I'm not sure whether to go with the 2000 or 3500 axle. My tear is going to be larger than the standard. It'll be 6'wide 5'high and approx 11' long..10' frame with a curved overhang. (Similiar size to MIKE'S BAJA)
Is a 3500lb w/brakes overkill? Or is the 2000lb w/brakes OK? Also I was told that a 0 degree offset was the same as a 4" drop. What is a 10 degree up angle equal to?? and the 22.5 degree up angle equal to?? Was also told I'd need 12" min added to the frame for the hub width, and more for the 3500lb. If ordering with brakes do I need a controller to?
I'd like to order it this week, since the prices go up next week.
Thanks, Ken
