by Nitetimes » Wed Aug 24, 2005 11:33 pm
It is up to you how you are going to use your compressor as far as what you buy, but I will say this, I would get one with the biggest tank you can get unless you plan to carry it around a lot. Those little 2, 4 and 5 gallon tanks are great for portability but, they run out of stored air quickly, which means you need to stop and wait for the tank to build up again, which can be very frequently depending on the tool you are using. My framing nailer usually gets 4 to 6 shots between runs with my 4 gallon portable compressor with the last shot not being entirely driven. So I would recommend getting at least a 20 gal tank, I know HD lowes sell some with 30/40 gal tanks that aren't terribly expensive, a lot of them are 110, made just for the home garage.
I guess I'm spoiled because mine has an 80 gal tank, a new head and a new 5 horse 220v motor. Yep, it takes up quite a bit of space, it's noisy and a bit irratating when it's running, but I never have to stop when I'm using my air tools. Even my sanders and spray guns which are air hogs.
Just another opinion from the peanut gallery.
Rich
- Thomas Jefferson -
