>>>>>Roly Nelson wrote:Kathleen, it sure is nice to flip up the hatch lid and dig into your cooler, located under the counter of your galley, without having to go to your truck. Lets see, it's good for storing all of those veggies, fruits and cold drinks, plus is makes for a good food-prep area, while chatting with your friends and sharing all of those meatless, greaseless delicacies. Make a two-way entertainment/computer area if you want, but really consider taking advantage of all of the valuabale storage space within your galley. My latest tear has no storage below the counter top, that space is for my feet. However it does have a small cabinet above, for paperplates and some-such stuff. Good luck on your build.
Roly, building the second one, (which I said I would never do.)
>>>>bdosborn wrote:One thing to keep in mind is that the galley bulkhead acts as a big brace for the trailer walls. Our walls got * a lot * stronger when I installed the framing for the bulkhead. You might think about finishing the rest of the trailer and just provision for a galley. That way, you can camp in it awhile and then add the galley later if you decide you need it. My guess is that you'll end up adding one. For us, the galley is what makes our Teardrop so much fun to camp in.
Kathleen wrote:<snip>
So are saying that it would not be good structurally to remove that wall?
How about making some kind of access from the inside to that area?
<snip>
