Well, here's my first technical question and I haven't found anything quite like it in the archives, so . . .
I am in the planning stage for a TD project - 5x10 Woody - and I want to have something other than a non-plywood grain to work with for my finished surfaces. There is a local outfit, Veridian Reclaimed Wood (see http://www.viridianwood.com/ ) that has the production facilities to press the veneer product to any substrate desired. The problem is, while they make that claim they pointed out to me that cracks and imperfections in the base surface will cause the veneer to be "drawn into" the flaw.
This became an issue when I asked if they could bond their veneer to either CDX or Marine grade plywood. They are primarily involved with creating panels, tables, etc. for an indoor environment and use MDF, which as we know is a TD "no-no." Being a newbie to this world of fabrication I need to ask if any of you have a point of view on the substrate with the highest quality surface that might be appropriate for the kind of application I have in mind.
I am sure that I am overlooking important details that will be needed for a reply, so fire away with your questions!
