I don't know why I didn't think of the T&G plywood. That's a great idea and cuts down on the labor involved. Thanks.
When I was working with the biscuit info, I thought about setting up cabinet frames and door frames for the cabintes. I like to design things, so I designed a frame jig to accomodate assembly of frames fro 9"x12" up to 32" x 36", the largest I can imagine needing for most applications. It whould work with either butt joint, tennon, lap, or corner-mitered frames (see disclaimer below). For my couch/bed, I will need to make a couple of frames 62" wide, but can to that with my jig with some finagling to manage the extra length. If anyone is interested, I put the plans for making this jig in one of my photo albums.
http://tinyurl.com/83ezj But, they are not in the correct sequence. They are in the TD Forum album, and the last one, Basic Frame Jig Construction should be the first oneviewed. The assembly is pretty self explanatory, but if anyone wants to build one, I'll answer questions. If anyone wants the larger .jpg files (page size), email or PM me and I'll email them to you.
DISCLAIMER: I haven't actually built and tested it, so I make no claims that the plans and the resulting jig are foolproof and will work without modifications.
