If you're like me, and have an older router that won't take the Porter Cable type template bushings, here's a site I found with what you need.
http://www.mlcswoodworking.com/shopsite ... tacc1.html
I have a couple of older Sears Routers that don't have the Porter Cable type base with the 1 3/16" diameter hole needed to accept the PC template bushings. I found this site that sells both the brass bushing set that looks like the one at HD, as well as a generic one with a universal base. They also have router bases for your router that have the 1 3/16" hole, which is what I am ordering for one of my routers. Also, they have different base plates for router stands and a universal centering alignment pin, which I am also ordering.
"This handy set-up tool is designed to fit both 1/4" and 1/2" router collets, and center the baseplate to the collet. It’s vital for inlay work, pattern router, and using any precision fence system. It will also indicate the exact center of any bit cut, which is important when locating grooves and dadoes. The centering /alignment pin can be used to check run-out on drill press, mill and lathe chucks."
They feature free shipping if you're not in a hurry, and I'm not. I ordered a set of Porter Cable template bushings at Amazon.com and got them for $9.99 after a $20 discount for applying for and getting their Visa card (instant approval, no waiting). I didn't need the card, but for a $20 discount, I got one. I'll just cut it up when it arrives. And, Amazon gave me free shipping too.
Anyone found any other good router accessory sites?
