Kuffle Creek Trailer Modifications
Postby Jimbo » Mon Jul 26, 2004 6:23 pm
Hey all, the Kuffel Creek mods for the HF trailer call for using a piece of Douglas Fir for a replacement crossmember. I picked up a piece of steel angle today and thought it might work better. Any thoughts?
Started many, finished none... Bought a TTT <Sigh> ;)
Jimbo
2nd Teardrop Club
Postby Clancy Courtney » Tue Jul 27, 2004 7:37 am
Jimbo, Thats exactly what I used. Don't know if it made any difference but I felt it would make it stiffer.
Clancy
Clancy Courtney
Images: 11
Postby engled » Tue Jul 27, 2004 8:20 am
Same here, I used a piece of 2" angle.
engled
Postby Joseph » Tue Jul 27, 2004 9:13 am
I'm not using the Kuffle Creek plans but I'm told I've done the same thing they call for in using one of the cross-members cut in half to secure the two four-foot sections of frame together.
In any case, I just did without that particular cross-member and it works fine. You can see my frame here.
Joseph
Joseph
Teardrop Pirate
Postby Joseph » Tue Jul 27, 2004 9:48 am
I should have added that if you look at my frame, you'll see that the missing crossmember is at the foot of the bed where there won't be much weight. The galley and the head and center sections of the bed are all supported by cross-members. I suppose I could have supported that by adding a cross-member on my wooden base frame to correspond to the place where the missing frame member would have been, but I didn't.
It has now travelled about two thousand miles and it hasn't been a problem.
Joseph
Joseph
Teardrop Pirate
HF Mods
Postby jlrelp » Wed Jul 28, 2004 12:20 pm
Hi Jimbo
I deid the same think used a 2" angle for the cross member, and I did not cut off the 2 1/8 in .. not making the cruve at the front.
best of luck John
John
jlrelp
Postby Jimbo » Wed Jul 28, 2004 6:32 pm
Did you all mount the axle over top of the leaf springs like the mods call for or keep them under the springs?
Jimbo
2nd Teardrop Club
Postby mikeschn » Wed Jul 28, 2004 6:39 pm
I definitely mounted mine above the springs...
Images: 479
Mount Springs
Postby jlrelp » Thu Jul 29, 2004 11:00 am
I did the same mounted the springs above the axle...
John
jlrelp
