JLaman wrote:I used ripped 2x4s at about 12" oc. I suspect most use 2x4s because the 2x2s at Lowes and elsewhere are like spaghetti. You can purchase premium 2x4s for less then $4 and end up with better product for less money.
JLaman wrote:If you calculate the section modulus (strength) and moment of inertia (stiffness) for a 3/4 by 1.5" deep member with 1/8 ceiling liner and 1/4" roof spanning a 5ft wide tear, the construction will support more than 40 pounds per square foot. This is considerably more snow load or wind load than could be expected in most cases. This requires a "composite" section consisting of the ceiling, inner spar, and outer plywood all carefully glued. This evaluation ignores the substancial benefit of the arching action that can be expected from the curved shape of most of the tears being constructed.
