Steel Studs
Posted:
Fri Jul 11, 2014 8:49 pm
by johnandtricia
I have noticed that on the grumman designs that everyone seems to use 2" x 2" to go between the walls and under the skin. Has anyone tried to use steel studs for this? and if so with what results.
Re: Steel Studs
Posted:
Sun Jul 13, 2014 1:04 pm
by ctstaas
I am not familiar with the Grummand but I have used steel studs in my build. I made my galley hatch frame from 1" square tubing. I also helped build a houseboat cabin using steel studs for commercial construction. Lots of advantages. I I were going to run wire through the wall, I would drill it out oversized and sleeve it with some brake tubing. to protect the wire. Use shrink wrap to give additional protection to the wire. Locktite has a new family of adhesives that seem very impressive for attaching siding to the steel.
Enjoy, Chris
Re: Steel Studs
Posted:
Thu Sep 18, 2014 4:09 am
by rmblefsh
