Skylights
Skylights
Postby rusty knukle » Mon Sep 29, 2014 11:42 pm
I want a real skylight one the wife can see the stars thru.Most of what I see is roof vents, ventilators.Anyone have any good ideas and how to install it into a rolled aluminum roof
rusty knukle
Re: Skylights
Postby Gage » Tue Sep 30, 2014 1:46 am
How about a moon/sun roof. Gives you a vent and also a great view of the stars at night. :thinking:
Image........Image
Image Image Image
Gage
Images: 28
Re: Skylights
Postby bobhenry » Tue Sep 30, 2014 6:06 am
Why install it "IN" the roof..... Just make it THE roof.
Images: 2614
Re: Skylights
Postby cheri832 » Tue Sep 30, 2014 8:29 am
Or you could go with a convertible top... fully screened with a marine vinyl top that snaps on. :?
Cheri
cheri832
Images: 15
Re: Skylights
Postby KCStudly » Tue Sep 30, 2014 8:56 am
If you are using canvas and paint, glass weave composite, or maybe even aluminum on a gentle arch, you can build up a flat flange area on both sides for the window to seat on. I am doing something similar for my vent fan. The difference from the tangent point to the raised area is only about 1/16 inch on my vent (14-1/2 inch run on a 520 inch radius).
Re: Skylights
Postby rusty knukle » Tue Sep 30, 2014 8:01 pm
Wow I like the sky roof I'll keep looking and plotting and let ya know how it goes.
rusty knukle
Re: Skylights
Postby Dobrodoc » Sun Nov 09, 2014 12:03 am
Gage
Where did you get the window? Is it difficult to instal?
Thanks
Russ
Dobrodoc
Re: Skylights
Postby Strop » Thu Nov 13, 2014 5:56 am
You might be able to get one from a car wreckers.
Strop
Images: 10
Re: Skylights
Postby OuttaHand » Wed Dec 24, 2014 12:03 pm
I bought a sunroof off of eBay. It may actually have been just a regular window from a camper. I can't remember.
But, anyway, the sunroof has a "rim" around the outside of it. So I built up an area between two of the roof spars to accept the sunroof.
When I built the roof, I placed two of the spars just the right distance apart to accept the window. Then I placed two braces between those spars where the ends of the sunroof would be.
After I got the sheathing on the roof, I cut out the opening for the sunroof and "dropped it in". I then drilled holes through the rim of the sunroof and used stainless steel screws to screw it into place. I also used a polyurethan sealer under the rim of the window to make sure it was going to be waterproof.
Now there was more to it than that, naturally. You can see pics from this in my build log here: http://webpages.charter.net/outtahand/littletow/build18.htm
It really adds a lot to be able to look out at night. Makes it a lot less claustrophobic inside. But you will want some kind of curtain for it. Sun coming through can really heat up the interior!
Teardrop newbie but camping "oldster"
OuttaHand
Re: Skylights
Postby mike-nikita » Wed Jan 28, 2015 6:35 pm
Gage wrote:How about a moon/sun roof. Gives you a vent and also a great view of the stars at night. :thinking:
Image........Image
Wow that moon roof looks exactly like what we were planning. was there any problems fitting it as a teardrop is thicker than a car roof
mike-nikita
Images: 53
Re: Skylights
Postby Gage » Wed Jan 28, 2015 8:26 pm
My finished roof thickness is only 1” and there was no problem fitting the sun roof in. Just take your time, don’t get in a hurry. ;)
Image Image Image
Gage
Images: 28
Re: Skylights
Postby rowerwet » Mon Feb 02, 2015 7:59 pm
Another option might be to add a trolley top with windows in the side. that way you have vertical windows that are much less likely to leak, yet are still easy to look out through lying down.
rowerwet
Images: 521
