If you look at the total cost and the hours of work, it makes sense to use the best materials and pay a little more now. You won't miss the extra money years from now but may regret any shortcuts.
I'll give that statement a double bingo.
(Use your imagination).
My experience with OSB (on a painted shed in a dry climate with an overhung roof) was horrible. I replaced it with the T-111 plywood that my house has on it. It's been there for twenty years. And no, I'm not suggesting you use T-111 but exterior plywood lasts longer than OSB. A lot longer. I also wouldn't suggest you use CDX plywood, because it has too many voids and seems frequently glue starved. I would think joinery with OSB would be problematic. Perhaps there's a way. Dunno.
Also, I don't think you could glue your exterior/interior sheathing using TB2 glue 'cause of the "glue" on the OSB (Is that stuff full of formaldehyde?)
3/4" AC plywood here, in the middle of Idaho and three hours from the nearest Home Depot, is $41. You might want to call around. When I build a teardrop, it costs me roughly $3500. Maybe more. Don't scrimp on your major items to save thirty or forty bucks.
Having said that... I've seen some builds on here that used OSB. I hope it works out in the long run. Most commercial camp trailers (the big-factory ones) use OSB in the floors and I think that's so they can get through the warranty period.
T
