Thanks, all--you've given me a lot of food for thought.
I wasn't planning on using the sandwich method, so I'm not sure that a wood template is as much of a priority for me--I was thinking of using 1x2 poplar studs with a 1/2" plywood exterior. (Is "studs" the right word on a teardrop? You know what I mean, anyway.) On the other hand, I'll be using a jigsaw and router for the first time ever on this project, and, to Paul's point, a template would give me the chance to practice on cheap materials. So I'm still undecided, now I'm undecided in a much more
informed way.
In any case, Woodbutcher, H.A., pohukai, and Tony make a very compelling case for how detailed my template--wood or paper--should be. I had just planned to use it for the profile, but it definitely makes sense to include the shelves, doors, & windows to test my plans.
I am using SketchUp, pohukai (as of yesterday, thanks to Dan L's wonderful tutorial
https://www.youtube.com/watch?v=r4TKpcjJ6h0&index=1&list=PLE232575796E3DB49 on youtube), but I what I see on the screen and how it feels in real life will probably be two different things...
Tom, I've just started reading your build journal (I'm up to Sept 7, '07)--I've been enjoying your attention to detail and willingness to experiment. I'm delighted to meet you! Your post reminded me of another question--you used MDF for your skeleton--why? Is it cheaper than comparable plywood? And if so, would it hold up better or worse than plywood in the case of a leak? BTW, I live just outside of Austin so I feel your pain, slogging away in those 100F+ days. I'm just hoping we don't have a repeat of 2011 during my build process. Or, indeed, ever.
Thanks, all!
