H.A. wrote:Rubber works great. Tou might consider TPO or PVC roof. Its much easier to clean.
Also damages can be welded, rubber you are stuck with glued uglier patches.
Shadow Catcher wrote:The roof on our tear is Filon and for one reason (if not others) I was able to attach the plastic solar panel mounts using 3M VHB tape with out drilling holes.
I was also able to install Kedar rail to support tarps with out drilling holes using VHB tape.
Life expectancy is also much longer.
I think the extra $ to go filon w be well worth the saved time and reduced maint., ill go w that.
iristhomas1299 wrote:Overview, TPO vs Fiberglass RV roofs have many differences such as material, durability, design, and cost,...But both of them are good for RV. Each one has its own benefits, so you can refer and the best one for you.
