noseoil wrote:I can understand your need for simplicity & an easy build. The other side of that coin is comfort, once things are built & you're using it. If a few dollars are well spent & time is spent in planning, there's no reason you can't have your cake & eat it too. If it costs a couple of weeks & a few dollars more to build, in the overall scheme of things, isn't it worth it to be more comfortable when it's finished? Just sayin'......
The problem is that right now because my job is out of town and I am trying not to waste money on hotels, I am tent-camping between 5 and 7 days per week. I am staying in an RV park on a military reservation (Jacksonville Naval Air Station), so I don't have anywhere to work on the TD.
If I'm lucky, I'm back home for two, two-and-a-half days per week. I'm spending time with my family and catching up on the "honey-do" list.
So I have extremely limited time to build this camper. And my mother-in-law is sick, so my wife has had to take a leave of absence from her job with a resulting loss of her income. That limits the money available.
This camper isn't for pleasure camping or my retirement. I need it NOW since I have to travel for work. My circumstances dictate the time and money restrictions.
I understand what you are saying, but unless I want to spend the next year or two living in a tent,
any camper is a vast improvement on my current situation. It doesn't need to be PERFECT, it needs to be USEABLE.
Right now, I am trying to plan out as much as I can so that when I do start the build it won't take any longer than necessary. I have plenty of time sitting in my tent right now to get organized...
noseoil wrote:If you're planning on an air conditioner, you will need 110 volt power, no way around this one yet for the load a small unit requires (400-500 watts when running).
I'm thinking that I'll add that in the spring, we're at the end of the hot weather soon. Bob Henry's "tack-on" AC concept means that I don't have to try and predict the unit size, etc. So I think that's the route I'll take.
Easy enough to put and outdoor plug on the camper to plug it into. But should I just put it on the 110 AC circuit? Won't that suck up all of the available power on that circuit? Would it better to also have the 30 amp service to handle that? Or at least leave room to install the 30 amp shore power? I may be tossing a small microwave in the galley (I have one just sitting in the garage, unused). I don't anticipate needing a lot of high-draw electrical gadgets, but I don't want to preclude an update later on either.
