- hatch strut example.jpg (39.16 KiB) Viewed 333 times
Hi,
I've been reading as much as possible about the gas struts and seems there are so many different ways to do this. My hatch is 5 feet wide, 67" from hinge to end (on the arc) and will end up being about 50-60 pounds.
I just bought 120 pound gas struts. I plan on mounting them as in these examples below as they are approximately 18" closed and 28" open...(I don't have exact length as I'm at work - but they are long).
The question is - can they be mounted like these images here and will there be any issues? For instance, when the hatch is closed, will it be pushing down (putting pressure against the hinge)?
I don't want to have to drill a ton of holes and would like to get it done right the first time. I think? that I understand where to put the brackets, I just want to know if this way of mounting them is OK. (Style 2 in below pics).
Thanks!!
