I just had a look at your build journal and it is great to see a student taking on a project like this. I am sure you are looking forward to going camping in the spring.
I debated with myself about ordering a hurricane hinge and ended up going with some experienced hinges from an old closet door. I sealed it up similar to what Bob did. Actually I remember looking at his pictures for inspiration. I used strips of walnut above and below the hinges and for the seal used a bike tire tube. It does need to flew quite a bit when the hatch opens and closes so a fairly flexible seal is desirable. I left the rubber overhanging at the end. A more flexible material allowed be to make the hinge cover narrower. I don't think there is any hinge that would look great with a woody, but this is simple, cheap and if you look at the pictures below I don't think it destroys the look too bad, ie- it isn't the first thing you notice when looking at the trailer.
The first trip I took with the teardrop, I just covered the hinges with clear tarp tape. It worked pretty good too.
By the way - when repacking those trailer bearing be sure not to make the mistake I did long ago. The bearings need a tiny bit of play in them. Otherwise they will heat and expand slightly, then heat and expand some more and then overheat and disintegrate or even melt the axle. The proper procedure is to tighten with a torque wrench, then back off and re-tighten finger tight, then back off to next cotter hole position. I like to use the ez-lube type hub covers with the grease nipple on them and never take the bearing apart again.
