Treeview wrote:I've got a 110v Miller that I like a lot. It's done some great work for me. Like most purchases there are lots of choices. Make your decision based on local spare parts vendors. If you can't get parts you're dead in the water.
Unless you NEED to do a lot of outdoor/windy welding get the gas and skip fluxed wire. YOu'll get a better weld.
I bought the larger spool of wire and keep the small spool that comes with the unit as a backup if I ever run the large spool out and I need to get the job done before buying more wire.
There are lots of good training videos on uTube. Then the fun starts! Melting metal.
It'll take a while to learn how to set the power and wire feed rates to get a good weld. I try to set up with a higher power and slower wire feed rate if I weld thick stock.
Dale M. wrote:My welder of choice for light work was a Hobart Handler 140.... Made in USA and has good warranty... And also have a online forum for welding /fabrication help...
http://www.hobartwelders.com/products/w ... andler140/
IF you want to save a few dollars and are not afraid of refurbished equipment...
http://www.hobartweldshop.com/refurbish ... t-welders/
IF want to learn to weld.... Go to Youtube and look up "weldingtopsandtricks".... This man is a pro and no nonsense ... There is a lot of hacks on Youtube but this man is not.... He also has a website ...
http://weldingtipsandtricks.com
I try to stay a way for Chinese made welding equipment as they are cheaply made and tend to fail when you want it most and its dubious where you can get replacement parts or warranty honored...
Also explore gas shield welding VS. solid flux core MIG.... My choice is gas shield but there is also times and places solid core wire is appropriate.... Even if you plan to use solid core (flux) wire consider a welder that has gas shield capabilities, not all low end machines (120VAC) have gas capabilities... With gas 'option' you get the best of both worlds....
Also 120V welder had limitations of in range of 3/16 to 1/4 maximum thickness they can weld in single pass, if you are going to weld "heavy" stuff consider going with a 240V machine... A better choice if you feel you need a bigger machine may be something like the Hobart 210MPV which can use a 120VAC or a 240VAC input and has capabilities of welding thicker materials on 240VAC...
Accessory or additional needs..
Welding helmet, my preference is Auto Darkening (AD). They also have capabilities of adding "cheater lenses" (1.5 and 2 diopter) for people with vision needs...
Good pair of welding gloves.
Welding jacket, not necessary but keeps good clothes good...
Extra roll of wire, usually roll of demo wire that comes on unit is very small...
You can use "non stick" spray cooking oils instead of expensive nozzle jell or anti spatter shield>
Good pair of diagonal cutters for clipping off excess with before starting weld (MIG 'tool' is nice but not necessary)...
Most manufactures (ESAB, Miller, Hobart, Lincoln) have support forums and there are several independent welding forums, great place to learn and ask for help (just like TNTT.com) ...
The adventure begins...
Dale
MtnDon wrote:Testing saves your eyes.
Also use arm protection to prevent arc sunburn. I have some sleeves made for the job for those days when it is too hot to wear the leather jacket. Electric arcs give off a huge amount of UV. That is one reason arc welders use a mask like helmet. Keep the UV off the face and neck. And get some good welders gloves.
lrrowe wrote:
I appreciate these comments Dale. I like that Hobart is USA made for sure. HF is obciously Chinese. Eastwood says theirs is made in China under their control.
