by daveesl77 » Fri Jan 22, 2016 8:52 am
I way, way overbuilt mine, so your numbers are probably fine. With Conch Fritter it has a 9" overhang on the sides and 12" on the rear. My floor structure is 1/2" ply, 1" framing I made, fully filled with eps foam board, then 1/2" on top. Everything is glued and screwed together. The bottom of the floor is coated with PMF, the top with the "mix". I can jump up and down on an overhang corner and no movement at all. Yes, it added strength, but also a bunch of wasted weight. If I do another, the max I'll go is 3/8ply, 3/4 insulation, 3/8 ply.
My floor deck is throughbolted to the frame, using nylon washers and silicone between the deck and frame. All bolt holes are filled with silicone.
If you aren't doing an overhang, then your design will be rock solid.
dave
