by LMarsh » Mon Feb 22, 2016 12:31 am
My guess would be anything chrome or stainless won't be flexible enough, maybe I'm wrong. I've looked at many different right angle trims and when it comes down to it looking good, it had better be flexible first, then worry about the cosmetics of the material. If its not flexible not only will it just be a huge pain to install, but kinks look terrible. I lightly polished and then clear coated some regular soft aluminum trim and it wasn't that hard. You can also always ask for a sample if you want to see what something you're considering looks like. Even with the aluminum trims some starts out looking better than others. I didn't polish it to a mirror finish but if its a smooth trim type without ridges or grooves, its always possible. I also tried my hand at annealing but I found it to be unpredictable and too much of a hassle when soft flexible aluminum trim is available. I melted a piece of angle from the big box stores right in half and even when my results were better it still didn't turn out looking very good once it was bent around a curve.
