Tomterrific wrote:I'm not sure what's up here? Are the trim rings with the windows you have not deep enough? Wrap the the trim ring with vinyl cut from a piece of cheap vinyl siding, or aluminum, which ever the existing trim ring is made of, to extend it.
T
kayakdlk wrote:I didn't use trim rings, as my windows didn't come with them either. I screwed through the outer ring into my roof for my moon roof windows. On the inside I smoothed the wood with epoxy (you could use a wood filler) and painted the inside lip black. It blends into the black windows frame and looks fine
Check out my build journal for more details and pictures (page 5 about 1/4 the way down) shows the moon roof inside and out and how I finished it.
Dan
Dan
