I'm using ridged foam board for the insulation in my walls and I'd like to know if anyone has used Loctite PL with ridged foam board.
In particular, what I'm using is "Foamular 250" from Owens Corning. It is made from "Polystyrene" and the instructions on the PL adhesive says not to use it on "Polystyrene bath tub surrounds, Polyethylene or for polypropylene applications requiring water immersion."
It also says "Adheres To: Foam Insulation."
This is not a "wataer immersion" application so I'd think it should work.
I've glued up a small sample and I've seen no adverse effects although it has not thoroughly cured yet.
Any thoughts or experiences you'd like to share?
Thanks,
