noseoil wrote:1/2" is plenty, depending on the thickness of the lid, but how will you get to it with the mattress in place?
Thanks for confirming my thoughts on the lip... I plan to use 1/2" Ply for the floor. There will be sufficient support in the floor, it's the lid I am concerned with.
Access to the storage is my next area of internal debate. I've thought of sectioning the mattress, however where to do that...
Here are a couple scenarios that have been running through my brain:
1) Do enough at the foot of the mattress to fold it up and over... Pros- The lid will either be loose , or hinged at the back, so this method would allow quick access to the storage area... Con - I have double the mattress thickness to lift things over, then put them in the storage area.
2) Do the same distance cut, but at the top of the mattress, fold the top down, then slide the mattress to the front to gain access to storage... Pro - Less restriction to the storage, as the mattress piece could be folded up to minimize blockage. Con - Basically remaking the bed every time I access the storage area.
3) 2 cuts in the mattress and stack everything vertical at the front of the trailer. Pro - full access without anything in the way of getting to storage. Con - even more dis-assembly of mattress and remaking the bed.
This storage area will not be a high traffic area, but more for 1-2 times per trip access, such as storing the rifle case while in transit for a hunting trip. Get there, pull out the case, take out the rifle and put the empty case back, make the bed. Don't need to get back to the case until it's time to case the rifle for the return trip. I can also store other items there, such as maybe heavier items that won't fit in the galley but I want to keep near the axle due to weight. I am also contemplating an on-board water tank for this area, and possibly the battery box. Obviously, the battery box would be sealed and externally vented if it ends up here.
I will have a small amount of head-board storage for light items, like extra pillows or blankets. I will also have exterior side access to the remainder of under-floor storage. I already have these access doors, as well as my regular entry doors.
