Question on 1/2" plywood sandwich wall - <Newbie>
Postby Spentfire » Mon May 23, 2016 1:34 pm
All:
I'm building a 4x8 benroy, and I am concerned about wall strength. My design is a sandwich wall with 1/8 luan exterior, 1/2 plywood interior with cut-outs for 1/2 inch foam insulation, and a 1/8 luan interior (i.e. no "stick" bracing). Now that I've started to cut out the excess 1/2 plywood for the insulation pockets, I'm noticing considerably more flex in the 1/2 ply than I was expecting.
My question is, once I get the insulation installed and the sandwich glued up, do you think that the wall will be structurally sound enough not to flex too much? I know everyone on TNTTT says not to overbuild, but now I'm worried about underbuild and flex! Did I goof? Should I have used a 3/4 internal ply?
Any help, consolation, or anti-hyperventilation meds greatly appreciated! :NC
Thanks!
Spentfire
Spentfire
Re: Question on 1/2" plywood sandwich wall -
Postby tony.latham » Mon May 23, 2016 2:34 pm
I'm on my phone right now so can't link photos. I built a 4x8 Grumman teardrop with 1/2" ac skeleton, 1/8" Baltic birch on the inside and 1/4" subfloor on the outside. The rear bulkheads were mortised and the spare were set ala Fredricks method. It's plenty strong.
But I suppose it depends on how much plywood you are hogging out and your ext/int ply.
Re: Question on 1/2" plywood sandwich wall - <Newbie>
Postby KCStudly » Mon May 23, 2016 2:43 pm
The strength comes from the skins and how far apart they are. Once glued up your wall will be almost the same as 3/4 inch ply; very strong. Just be careful handling the skeleton in the meantime.
Postby tony.latham » Mon May 23, 2016 11:48 pm
"What he said."
I think KC is right. :thumbsup:
TL
Postby dales133 » Tue May 24, 2016 2:49 am
Not to mention attachment to the floor and roof spars will give it all the streth it needs
dales133
Postby Spentfire » Tue May 24, 2016 12:03 pm
Many thanks, everybody! Sometimes you just need a little confirmation!
Best to you all :wine:
Spentfire
Spentfire
Postby daveesl77 » Tue May 24, 2016 1:48 pm
Mine is 5+ feet high and 10' long. Walls are 1/8" internal ply, 3/4"x3" cross joined, wood frame with solid foam in all voids, 1/8" external ply covered with 3/16" thick cedar strips. All wood framing was half-lap joined. Once walls, floor, and curve is tied together it is like a rock. I honestly believe you could roll it over and it would not be structurally damaged.
dave
daveesl77
Images: 273
Postby KCStudly » Tue May 24, 2016 5:19 pm
I'm actually considering rolling mine over so that I can glass the bottom! ...maybe.
Postby aggie79 » Tue May 24, 2016 5:32 pm
daveesl77 wrote:Mine is 5+ feet high and 10' long. Walls are 1/8" internal ply, 3/4"x3" cross joined, wood frame with solid foam in all voids, 1/8" external ply covered with 3/16" thick cedar strips. All wood framing was half-lap joined. Once walls, floor, and curve is tied together it is like a rock. I honestly believe you could roll it over and it would not be structurally damaged.
dave
They roll over pretty easy if using a curved profile:
And stand on their nose if you have a flat front:
Postby tony.latham » Wed May 25, 2016 9:34 am
A rolling teardrop gathers no dust.
