Gap in trailer frame and subfloor
Postby bosleybeebop » Thu Jul 28, 2016 9:10 am
On the Northern Tool trailer the side rails overlap the cross members by an 1/8", when attaching a plywood subfloor how have you addressed that gap along the cross members before attaching the floor?
Do nothing, the difference is negligible or did you place some kind of spacer or foam?
thanks
bosleybeebop
Re: Gap in trailer frame and subfloor
Postby KCStudly » Thu Jul 28, 2016 1:19 pm
Most people add a sliver of wood ripped on a table saw. Some have used plastic strip material as a shim. I think I even saw one builder use paint stir sticks.
Postby les45 » Thu Jul 28, 2016 5:01 pm
+1 on KC's comment. I cut small strips of wood and glued them to the plywood. Also drilled holes in plywood for the bolt heads. Located holes by placing plywood on frame with clamps and then using a hammer to beat on each bolt head location. The bolt head leaves a dent in the wood. Flip the plywood over and drill the bolt head dents in the wood with a 1" spade bit.
les45
Images: 605
Postby daveesl77 » Thu Jul 28, 2016 5:15 pm
I have the HF frame, but it has the same offset. I was going to use wood strips, but then remembered I had some 1/8" aluminum bar stock laying around so I made the shims out of those. Either would be fine.
dave
daveesl77
Images: 273
Postby bosleybeebop » Fri Jul 29, 2016 9:02 am
Much appreciated :thumbsup:
bosleybeebop
Postby Budowski » Tue Sep 13, 2016 11:29 am
I welded on 1/8th metal tabs on the inside cross members, then painted.
Budowski
Postby aggie79 » Tue Sep 13, 2016 12:39 pm
When I had a HF trailer for hauling, I just used fender washers.
Postby Nobody » Wed Sep 14, 2016 9:38 am
I used the HF 1800# trailer in 2006. It had the same offset so when I built my floor using 2x2s (actually nearer 1 1/2x1 1/2") for floor joists, when I bolted the floor frame to the trailer chassis I just slipped a couple of flat washers between the joists & the chassis cross members. The bolts wen through the washers into the chasis. It has worked for many miles & over 10yrs.
Harvey -
Nobody
Images: 342
