Page 1 of 1
Bending aluminum tubing
PostPosted: Fri Aug 19, 2016 11:16 am
by quack24
Anyone have suggestions or experience bending aluminum tubing I'm trying to figure out how to bent it for the framework of my ttt its 3/4 square by 1\8 I couldn't order full length pieces so I ordered 8 foot pieces and I'm going to attach them together by using 5 inch pieces of 1/2 inch tubing inside and riveting them together
Re: Bending aluminum tubing
PostPosted: Fri Aug 19, 2016 4:33 pm
by Juneaudave
I would message Alaska Teardrop AKA Fred. He pretty smart and makes some extremely nice trailers. You should probably also check the construction thread for Freds Northern Lite Trailer http://www.tnttt.com/viewtopic.php?f=27&t=51991&p=956704#p956704
PostPosted: Sat Aug 20, 2016 12:18 pm
by dmdc411
Would something like this work? I use these to bend electrical conduit. Takes some time to get good at it, but not hard at all!!
http://www.googleadservices.com/pagead/ ... IJQ&adurl=
PostPosted: Tue Aug 23, 2016 8:32 am
by alaska teardrop
Thank you, Dave, for the compliments. It means a lot coming from the man that built a beautiful award winning teardrop. :)
Quack, I've read your posts and am a little confused as to what your plans are. May I suggest that you start a build thread, post pictures & drawings and ask questions there.
Tube bending: you could try cold bending the tube around a form such as a truck wheel of the diameter you want. You could try making a conduit like bender to your radius. But my best suggestion to get matching bends of all your arches would be to find a local machine shop/fabrication shop that has a ring bender with 3/4" square dies. Pay for an hour or two labor and be done.
Tubing: Why you are using 3/4" x 1/8" x 8' tubing? Find a local industrial steel/metals supplier. They should stock or be able to order extruded aluminum shapes in 20' lengths. Also sheet aluminum in a variety of types & sizes.
Rivets: I highly recommend using closed end aluminum structural rivets installed with a pneumatic rivet gun. You should be able to find them at a local industrial supply store.
Good luck, Fred
PostPosted: Tue Aug 23, 2016 7:41 pm
by tac422
halfway down this page is a homemade tubing bender ...
viewtopic.php?f=50&t=66629
PostPosted: Tue Aug 23, 2016 9:11 pm
by Iain Hall
Harbor fright do a nice tube roller for a couple of hundred bucks but I made my own Image
PostPosted: Mon Sep 05, 2016 11:58 am
by ssuuki19
Hi I am new to the forum, just getting to my first post but saw this - I paid a supplier to bend the 1" square tube to the required profile for my build as I was told aluminum would rather 'tear' than bend, especially on any type of aggressive bend. It cost a lot of money for the two roof splines, but the profile was perfect.
