Building a Squaredrop similar to this only 5'x8'. What material should I use on the roof? Keep in mind that I do want a roof rack on mine for kayak and the like.
Sent from my SM-G900V using Tapatalk
les45 wrote:If your roof rack will fasten to the walls like the one in the pic, then your roof can be anything you want it to be. On my weekender, I used 1/4" plywood on 1X2 spars. However, my walls were 3/4" plywood which would easily hold a roof rack mount. If your side walls are lightweight composite, then you just need to provide framing that will accommodate the location of your roof rack mounts.
stanger1944 wrote:Were your 3/4 walls a single plywood panel, no insulation? Also did you use birch ply for the roof and walls?
Users browsing this forum: No registered users and 21 guests
