KCStudly wrote:If you don't mind having a divider or even just a stile, you could do mini barn doors on the lower face, perhaps with a slide out tray on heavy drawer extensions. This seems to me to be the easiest/most efficient way to seal and latch the lower section, and would allow either door to open independently (as apposed to doors that overlap).
The upper hatch could be extended just enough to act as a drip edge for the lower doors, but would seal independently so that you don't necessarily have to open it to allow either of the lower doors to open.
How did you intend to seal the hatch along the counter edge? I don't see any provision for that in your current arrangement, unless you planned on having an angled lip on the lower edge of the upper hatch so that there is a spot for a weather seal to land on the upper edge of the counter rail.
swoody126 wrote:(discussing going <35mph on US 380... )
JaggedEdges wrote:swoody126 wrote:(discussing going <35mph on US 380... )
That'll learn you for trying to drive against the wind
Though were they thinking you were trying to spot UFOs/Secret aircraft or something?
swoody126 wrote:the space you are proposing to keep the cooler would be called THE BOOT on a chuck wagon as seen behind the deputy's legs (discussing going <35mph on US 380... )
swoody126 wrote:seems pretty simple to this ole chuck wagon cook
heavier items were carried in the lower compartment for obvious reasons
when opened up the the tailboard/work surface would extend behind the door of the boot which becomes another shelf to keep stuff off the ground
just another way of skinnin a cat...
btw, this Ford TT truck based chuck wagon, powered by 4 of Henry's gasoline drinking horses, was not uncommon for units beginning in the mid > late 1920's
sw
steve cowan wrote:swoody126 wrote:seems pretty simple to this ole chuck wagon cook
sw
That is a cool looking rig you got there.
