QueticoBill wrote:I'd suspect the 3/4" ply sides would provide all the vertical support necessary, but would worry about any lateral movement (strong wind even) and if there was any risk of the walls "folding". May not be. Its just if walls are not vertical and load is pushing them to lean at all.
My concern is the wood and lag bolts holding the weight of the rooftop tent and two or three people.
Is there a way to run a regular bolt through that blocking? It'd be much stronger. I assume the block is glued and screwed?
I haven't installed the roof so I could run a bolt through.
tony.latham wrote:My big concern would be the zero-dark-thirty trip down that ladder. I'm talking night terrors.My concern is the wood and lag bolts holding the weight of the rooftop tent and two or three people.
Aguyfromohio wrote:QueticoBill wrote:I'd suspect the 3/4" ply sides would provide all the vertical support necessary, but would worry about any lateral movement (strong wind even) and if there was any risk of the walls "folding". May not be. Its just if walls are not vertical and load is pushing them to lean at all.
I think you have that exactly correct. Back in statics classes we called it "buckling".
Like any column, the side walls are tremendously strong in pure compression.
The trouble starts when a bit of sideways movement sets in.
It's hard to quantify, that what the class was teaching us, Euler's formula and all that.
If the coach is solidly braced at the front and back bulkheads, with a strong corner connection at top and bottom to make a stiff box, it might be OK.
When there's two adults in the tent and one hornet flies in, things could get bouncing around pretty badly.
QueticoBill wrote:I worry about the gust of wind more than the hornet or some nocturnal activity.
djohnsonnv wrote:An erected RTT will add additional lateral wind loading. Lateral resistance isn't hard to overcome with a rigid skin and bulkheads. This is demonstrated by the cheap IKEA/Walmart bookcases. These bookcases will fall right over without backing yet becomes fairly sturdy when a thin sheet is applied to the back. IMO a solid skin will provide better resistance than blocking or bracing.
Also buckling wouldn't come into play. Buckling is a failure that occurs when the supporting member is overcome by the internal stresses. This occurs when very thin members have very large spans. I would elaborate further but also had a hard time staying awake during structural analysis.
KCStudly wrote:I'm with Tony. The typical TD box with good construction, bulkheads and cabinetry is probably going to be more than rigid enough. It's those pesky lag bolts that worry me. Not the first time, probably not the fifth time, but into soft wood, probably won't last forever before wallowing out.
Not an apples to apples comparison, but case in point, the pumpkin chunkin rules were updated a few years back to disallow lag bolts. Too many wooden catapults were falling apart when their lag bolt joints wiggled apart.
Through bolts with washers or T-nuts won't pull out.
