Attaching edge trim
Attaching edge trim
Postby Kim Armstrong » Fri Mar 23, 2018 8:34 pm
What kind of screws or fasteners do you use to hold the trim on with when you use plywood for your sides? I know screws don't hold well in the edge of plywood. Thanks
Kim Armstrong
Re: Attaching edge trim
Postby tony.latham » Fri Mar 23, 2018 9:00 pm
Kim Armstrong wrote:What kind of screws or fasteners do you use to hold the trim on with when you use plywood for your sides? I know screws don't hold well in the edge of plywood. Thanks
#6 stainless panhead screws. Pre drill. Get everything dry fitted and then remove. Squeeze sealer into the screws holes and a bead along the edge and screw it back down.
:beer:
Postby John61CT » Fri Mar 23, 2018 10:07 pm
3M 5200 if you want it to never come off.
3M 4200 and Sikaflex-11 FC more gentle, LifeCaulk & 3M 101 even more so.
All seal, have flex, even the 5200
Proper planning and prep are critical.
Butyl tape for sealing only, no adhesion.
John61CT
Postby Kim Armstrong » Sat Mar 24, 2018 1:52 pm
Thanks
Kim Armstrong
