Curtains
Curtains
Postby Fiddlin'Billy » Sun Apr 15, 2018 3:26 pm
My wife is making curtains for our teardrop. It has manufactured doors. How does one attach curtains to that style of door w/o damaging them?
Fiddlin'Billy
Re: Curtains
Postby tony.latham » Sun Apr 15, 2018 6:25 pm
I installed marine curtain tracks above the door frames.
https://www.sailrite.com/Curtain-Track-Horizontal-Aluminum-48
Works great. 2' will cover a Vintage Tech glass door. You have to buy the snap-on tape, carriers and end stops if I recall.
Re: Curtains
Postby linuxmanxxx » Sun Apr 15, 2018 6:45 pm
I just got some elastic pushed through curtains and attached right above door to wall. Stretched taught and it worked perfect.
Sent from my Pixel 2 XL using Tapatalk
linuxmanxxx
Images: 10
Re: Curtains
Postby steve cowan » Sun Apr 15, 2018 8:29 pm
We used cheap adjustable width curtain rods hung on end brackets.
steve cowan
Images: 129
Re: Curtains
Postby Woodbutcher » Sun Apr 15, 2018 9:00 pm
I used a small rod that I shortened to just a few inches wider then the window. My wife sewed me a double sided curtain that rolls up and is secured with velcroe. Works great, I do all my trailer curtains this way.
Woodbutcher
Re: Curtains
Postby les45 » Mon Apr 16, 2018 2:41 am
We made our curtains out of a cloth shower curtain with the metal grommet rings at the top. They hang from two cup hooks at the upper corners of the door and are opened by simply dropping one side and re-attaching to close.
les45
Images: 596
Re: Curtains
Postby Nobes » Thu Apr 26, 2018 10:31 am
we use tension rods in the window opening in the door
Nobes
Images: 508
