Home made hatch supports
Postby Steve_Cox » Mon Feb 13, 2006 4:26 pm
TomS wrote:Steve, I like your idea. It's very original. What happens if the wind lifts your hatch? Will the springs stay straight and keep supporting your hatch?
Tom sorry about the delay in answering. Wind seems not to be a factor, as a mater of fact, when opening the hatch I over-extend the supports a little to get them perfectly aligned before putting the weight of the hatch onto the supports. It takes very little misalignment for them to start to fold. I think larger diameter springs might be better. Also think any close wound, easy to flex spring would work.
Steve 8)
Steve_Cox
Images: 196
Postby Steve_Cox » Mon Mar 20, 2006 6:28 pm
Steve 8)
I'm pretty sure no one built hatch supports like in this sticky. If you had, I'd probably heard about it by now.... After accidentally tripping the hatch supports and having the hatch fall on my head a few times, I decided it was time to "beef" them up a little. I went up to 1" diameter springs, about $6 at Mcmaster.com. I used stainless bimini top fittings from the boat surplus store. It works great!
Link to new hatch support photo
Steve_Cox
Images: 196
Postby surveytech » Mon Mar 20, 2006 9:52 pm
steve,
do you by chance remember the part number for those?
I think they may be perfect for my tear.
thanks,
walter
surveytech
Images: 6
Postby Steve_Cox » Mon Mar 20, 2006 10:01 pm
surveytech wrote:steve,
thanks,
walter
Part Number: 9664K33 $5.89 Each
Type
Continuous-Length Extension Springs 36" long
Steve_Cox
Images: 196
Postby Ken A Hood » Mon Mar 20, 2006 10:03 pm
Ken A Hood
Images: 42
Postby Steve_Cox » Mon Mar 20, 2006 10:31 pm
Ken A Hood wrote:ANOTHER SUPPLIER
I believe you will find those hatch assists to be about 8" to 10" too short for a tear drop hatch. Just my opinion.
Steve_Cox
Images: 196
Postby surveytech » Tue Mar 21, 2006 4:18 am
Steve,
thanks for the info!
what a great idea.
surveytech
Images: 6
Postby halfpastsix » Mon May 31, 2010 3:46 pm
I made these.
They also latch, so they won't come down unless you want them to.
halfpastsix
Images: 21
Postby Cliffmeister2000 » Mon May 31, 2010 4:25 pm
Can you un-latch both and lower the hatch by yourself, or does it take 2 people? :thinking:
God Bless
Cliff
♥God. ♥People.
1 John 4:9-11
My Teardrop build pictures
Cliffmeister2000
Titanium Donating Member
Images: 157
Postby halfpastsix » Mon May 31, 2010 4:30 pm
Cliffmeister2000 wrote:Can you un-latch both and lower the hatch by yourself, or does it take 2 people? :thinking:
It can be done by one person. I took the spring out of the latch on the one side so it will latch automatically on one side and manually on the other. When you lift the hatch up to release the sprung catch, the other one unlatches with gravity.
halfpastsix
Images: 21
Postby Steve_Cox » Mon May 31, 2010 5:40 pm
Hey !!! Start your own hatch support thread :lol:
This one died of old age 4 years ago. 8)
BTW, the old hatch supports are still working and the plastic hinge is still together too. The trailer is on it's 2nd owner.
Steve_Cox
Images: 196
Re: Home made hatch supports
Postby Paradiseteardrop » Sun Sep 07, 2014 1:27 pm
I made use of the holes in the trunk lid ribs where I had the ribs bolted together to shape and sand. A long 3/8 rod there to a 1/2" conduit pipe down to the table top . A 3/8 rod in the end goes into the table top through a finger pull with a 3/8 hole in it . The rod that goes in to the table has a hole in it to put in a pin if the wind is blowing.
Paradiseteardrop
Postby Steve_Cox » Mon Sep 08, 2014 8:40 am
Some old threads never die 8) February 2006 was when this one was started. If I was to build another tear, I would use the close-wound springs and boat Bimini top hardware again, they put no load on the hatch when it was closed. They automatically supported the hatch when raising.
34278
Steve_Cox
Images: 196
Postby clamlamp » Thu Jan 11, 2018 12:33 am
just discovered this! So I'm guessing the spring bends when closed and supports while open? When you want to close it you have to push the spring? How does it not pop out of the mounts? I wish I could see a video
clamlamp
Postby S. Heisley » Sat Jan 13, 2018 11:35 am
clamlamp wrote:just discovered this! So I'm guessing the spring bends when closed and supports while open? When you want to close it you have to push the spring? How does it not pop out of the mounts? I wish I could see a video
Hi, clamlamp:
That TD was sold to someone in Michigan? or Minnesota? years ago. This fellow, Steve, doesn't get on this website anymore. He hasn't been on this website in a year or two (or more?). However, the Bimini Top hardware where the spring is inserted has a set screw to hold the spring in. That's all I know. Sorry that I can't help more.
Images: 490
