skeleton walls vs framed walls
Postby cr500taco » Sun Jun 03, 2018 9:00 pm
I've been doing a lot of research for building my first trailer. I've seen the skeleton method and framed method for insulating, but I am wondering what's the pros and cons of each?
cr500taco
Re: skeleton walls vs framed walls
Postby Sparksalot » Sun Jun 03, 2018 10:06 pm
I think this mainly depends on the skinning method you choose. For example my tear walls started as 4x10 sheets of 3/4" oak veneer. That made the decision to frame the walls, then use a 1/8" birch interior skin an easy one.
Done? Surely you jest. A teardrop is never "done".
It's got a cop motor, it's got cop tires, cop suspensions, cop shocks.
Sparksalot
Images: 533
Postby tony.latham » Mon Jun 04, 2018 10:58 am
I've seen the skeleton method and framed method for insulating...
I guess I'm not quite understanding the "framed method" part of your question. I've built skeleton walls using both 1x 4s and plywood. Using plywood is much less labour intensive. Using "sticks" is a little cheaper.
If you look at this wall my wife is working on, you'll see lots of structural stuff that would be hard to add by some sort of framing. Everything in this skeleton is done for a reason and adds a hard point for something inside or outside the cabin.
:thinking:
p.s. In the long run, I chose not to attach the fenders to the walls since this 'drop was built to boondock.
Postby Billinthedesert » Mon Jun 04, 2018 5:16 pm
Tony, let's see if I have your preferred wall framing correct: 1/4-inch ply over a 3/4-inch "skelatized" interior wall frame, interstices filled with 3/4 rigid foam insulation, inside and outside skins bonded to frame with PL Premium? Just look at all those beautiful clamps ...
Billinthedesert
Postby cr500taco » Mon Jun 04, 2018 7:38 pm
:thinking:
Thanks, Tony
By framed I do mean "sticks" as you put it. IE stud framing. Would a plywood skeleton be just as insulated or less insulated as 1X4 with the 1x4 turned sideways? I plan on using the trailer in around 30* weather if not a little colder.
Sent from my SM-G950U using Tapatalk
cr500taco
Postby KTM_Guy » Mon Jun 04, 2018 8:53 pm
This is what he meant by using 1X4's. you cut them to build the Skelton instead of cutting it out of plywood. Lots of angle cuts for the curves. I went this way because I want 1" thick walls for insolation. And the other think I can't find 3/4" rigid foam.
You don't see many builds the way you are thinking like you would build a stud wall with top and bottom plate on a teardrop with a rounded roof. The reason is what would be the top plate would need to be curved and I'm not sure how to do that easy.
If you build something like a weekender, it would be easier to build using a stub method.
Todd
KTM_Guy
Images: 173
Postby cr500taco » Mon Jun 04, 2018 9:07 pm
KTM_Guy wrote:Image
Todd
Thanks Todd,
My trailer is going to be more of a box style and not tear drop style. It will have a flat roof with it angled in front. Don't know what style that will be called.
Daryl
cr500taco
Postby Billinthedesert » Tue Jun 05, 2018 10:16 am
Daryl, if weight is not an issue, you could use 2X3 studs, but that eats into interior space, although adding room for thicker insulation.
Billinthedesert
Postby noseoil » Thu Jun 07, 2018 8:00 am
I like the cutting method for plywood skeleton walls. All of those little blocks are too much work for me, just sayin'
137818
137905
noseoil
Images: 106
Postby tony.latham » Thu Jun 07, 2018 9:38 pm
Billinthedesert wrote:Tony, let's see if I have your preferred wall framing correct: 1/4-inch ply over a 3/4-inch "skelatized" interior wall frame, interstices filled with 3/4 rigid foam insulation, inside and outside skins bonded to frame with PL Premium? Just look at all those beautiful clamps ...
Exactly. When you're shopping for 1/4" ply, see if they've got underlayment ply. The stuff I get here in the middle of Idaho is cheaper and much better than 1/4" AC ply.
Postby tony.latham » Thu Jun 07, 2018 9:42 pm
Either way, the voids will have 3/4" of hard foam insulation.
You should be snug as a bug.
We use an inexpensive 12V electric blanket to preheat our beds on those chilly nights.
