2" 100 wall square tubing for 5x8 Teardrop Frame?
Postby anothermike » Fri Jun 29, 2018 8:00 am
I have some surplus tubing I had planned to use for a storage cage. I have been told it is too light to use as a utility trailer, but I don't know if it would be sufficient for a 5x8 teardrop build.
I'm not set on using it at all, so a simple "nope" is all I need to hear from someone in the know. If it will work, I can get started today without having to go out for material! Thanks!
anothermike
Re: 2" 100 wall square tubing for 5x8 Teardrop Frame?
Postby Aguyfromohio » Fri Jun 29, 2018 9:30 am
anothermike wrote:I have some surplus tubing I had planned to use for a storage cage. I have been told it is too light to use as a utility trailer, but I don't know if it would be sufficient for a 5x8 teardrop build.
Can you tell us what you mean by "100 wall"? Do you know the wall thickness in inches or millimeters, or maybe the standard steel gauge?
Aguyfromohio
Images: 76
Postby anothermike » Fri Jun 29, 2018 9:51 am
Sorry. That is what they call it at the steel place. Thought it was a common description. The wall is 100 thousandths of an in thick. So in between 1/16 and an 1/8th. Pretty thin, but too thin?
anothermike
Postby Aguyfromohio » Fri Jun 29, 2018 10:37 am
anothermike wrote:Sorry. That is what they call it at the steel place. Thought it was a common description. The wall is 100 thousandths of an in thick. So in between 1/16 and an 1/8th. Pretty thin, but too thin?
I don't consider that thin wall square tube at all. 0.100 inch wall thickness is pretty stout stuff for a 2 inch square tube.
That's not a standard gauge if the description is accurate - it would be thicker than 13 gauge (an unpopular gauge) but thinner than 12 gauge (a common size).
On our trailers we built the frames with 14 gauge 2 inch tube, that's a wall thickness of about 0.080 inch. I was going to go with even thinner, 16 gauge, but my welder said it's getting so thin it was hard to weld without burning through.
Aguyfromohio
Images: 76
Postby anothermike » Fri Jun 29, 2018 12:45 pm
Awesome. I will mic it later, to be sure. But good news for the build start!
anothermike
Postby KTM_Guy » Fri Jun 29, 2018 9:31 pm
I would use it if I had it. I'm going to picking up steel soon (I hope tomorrow) and will probably get 12 ga 2X2. and 2x2x1/8 angle.
Todd
KTM_Guy
Images: 193
