which way should my doors open.
Postby k1w1campa » Tue Jul 03, 2018 4:25 pm
Ok I've done the search routine, tried alsorts of different key words but still cant find what Im searching for and that is, does it matter which way my doors open (suicide or normal)
this is the shape of my door and I'm wondering wether to hinge at the front or rear of the door. Input from the experts is appreciated :)
td door.JPG (132.77 KiB) Viewed 665 times
Not everyone drinks from the fountain of knowledge, some only gargle!
k1w1campa
Re: which way should my doors open.
Postby Woodbutcher » Tue Jul 03, 2018 4:32 pm
I only hinge the front of the door. Should the door ever come open while driving you stand a good chance of losing it.
Woodbutcher
Postby coyote » Wed Jul 04, 2018 6:45 am
My tear is "normal" works perfectly fine. My old Scotty is "suicide". Only advantage I see...it helps me stay awake on longer runs. I check mirror repeatedly, in terror that it will spring open! (in fact, during rebuild, I wanted to turn door frame upside down and cure this....Darlin' bride expressed her thoughts....just keep watching mirror!) Coyote
coyote
Titanium Donating Member
Postby 2bits » Mon Aug 13, 2018 11:43 pm
Whichever flicks you big understanding the obvious disadvantages of a suicide door but it is not a worry if ti never flops open! Hell you can do a Delorean top hinge! 8)
Thomas
2bits
2bit Member
Images: 16
Postby teddy » Tue Aug 14, 2018 2:48 am
In my case it was simple, suicide doors wont clear my fenders, looking at yours, you might have the same problem.
teddy
Images: 187
