tearlurker wrote:I’m confused about this, mostly because I have limited router experience. Can someone explain or better show me with images how to cut the 1 and 5/8” rabbet for the headliner? Do you use an edge guide? I want to do it on a plywood skeleton rather than stick built. For what it’s worth, I have read Steve Fredericks manual but I really could use some guidance.
Thanks!
tearlurker wrote:So that’s two thumbs up for the URB and Steve’s method. Re-reading that section, this may be a better option because it eliminates having to go back and create additional blocking. Using a jigsaw on two boards sounds a little tricky. I would imagine the blade wants to bow out a bit.
KTM_Guy, how did you handle the bottom ledge of your walls? Did you route them out?
DWT77 wrote:Using a jigsaw on two boards sounds a little tricky. I would imagine the blade wants to bow out a bit.
