Wood sided trailer is having issues. Suggestions wanted
Posted: Sun Feb 17, 2019 12:02 am
So I built a custom off road style Teardrop trailer and decided for exterior to use 1/4” Baltic Birch Plywood. After the trailer was built we filled in all the screw holes with bondo then sanded the wood and sprayed the bare wood with Raptor liner. It when on think and dried super hard. I thought with as much as we put on this was going to be bullet proof. But seems with Heat, cold and rain the wood is contracting and shrinking and causing the Raptor liner to crack and now I’m seeing bare wood and having seam gaps. At this point I don’t want to have to take all the wood off because it will destroy the trailer because the screws were counter sunk and bondo’d over and I’ll never get them all out. Is there anything I can do to save this trailer? Is there a light weight fiberglass or something I could put over the top of this or do I just keep piling on the Raptor Liner. I was considering maybe trying to find some type of rubber seal like Flex Seal and just painting the entire trailer with a bunch of cans of that but not sure if that going to work either. Any suggestions?
