from the second week into my build (October 16, 2011) working on it wrote: I had a 50"x60" (220 lb.) frame on 8" wheels with an overall length of 102" to start with. Now, 2 weeks later, I've reinforced all areas, boxed in a 50" x 96" area with 1.5"x 2.5" tube, and lengthened and strengthened the tongue with new 3"x 3" x .188 square tube (to a new total length of 140"). Plus, I've installed new 5 on 4.5" hubs, and gone to 14" wheels. I haven't put the new fenders on yet, but I estimate that the new rolling weight at a frog's hair under 500 lbs. My goal at coming in at under 1000 lbs/100 lbs tongue weight seems very iffy right now.
* Actually, it came in at exactly 400 lbs, with fenders on, wheels & tires, and a 3/4" floor installed and polyurethaned....
- starting point: derelict 50" x 60" frame (w/11 gauge tubular steel perimeter & angle steel cross members)
- replaced single beam tongue with longer, thicker 3"x 3" x 3/16" tube
- 1.5" x 2.5" 11 ga. tubing 24" added... to the rear, with center spine also
- ...12" added to front, with center spine sistered to tongue and three cross members
- completed, but wish that I'd reversed the addition configuration (caused too much rear bias, at first)
- 400 lbs after deck was added
* I left the new end tubes open (instead of being capped/sealed), so I could install/access wiring inside, and let any subsequent moisture have a chance to evacuate, instead of being trapped inside. So far, the added steel tubing hasn't rusted at all, and made the frame easier to work on, and stronger than if I'd used 1/4" angle steel as the extension pieces, as I had intended originally (to be bolted together, not welded on).
* The 1/2" plywood floor was initially bolted to the angle steel cross members with 3/8" carriage bolts, but after layering-on a 1/4" Luan sheet (using TB2), I used Tek screws to permanently secure the completed floor to the perimeter of the frame (thirty-eight screws thru wood into the tubular steel). The resultant rolling trailer was much stronger than needed (exception: the spindly 1.25" square-tube axle, which I replaced in 2014, with a 3500 lb Dexter axle, 3000 lb springs, & massively-strengthened frame rail additions, using 1/4" angle).
* The 11 gauge tubing would've been quite adequate, but an over-tightened spring hanger nut had caused it to rip loose, and the new complete axle/spring/hanger assemblies needed a repaired and/or reinforced frame rail to mount on. Otherwise, 11 gauge was fine. 2" x 3" x .188" is overkill, especially if it is on a 4x6 sub-1000 lb trailer (my 4x8 is over 2000 lbs, so I went
big! on the steel).
* Unless you already have the steel tubing, then get (1.5-2)" x (2.5-3)" tubing; 11 gauge (.120") will be plenty strong for your usage.
