Anyone have any experience in this area?
tony.latham wrote:Anyone have any experience in this area?
I don't, but for $10 you can get an aluminum cutting blade for a circular saw.
T
Just hoping to find something a little smaller.
les45 wrote:I'm getting ready to skin my latest project (retro standy). I'll be using 16" wide corrugated aluminum panels very similar to those that came on my original pop-up that is being converted. I'll be cutting square ends and a few diagonals. I need a tool that will cut very precisely but I don't want to invest a lot in a high end tool that I'll only use once. I've got the usual nippers but those are a pain in the butt and are hard to keep on a straight line, especially after you get a few inches into the cut. Anyone have any experience in this area? Thanks.
M C Toyer wrote:(...)
I recently had to cut about 500 24" long sections from a 1000' long roll of 16" wide 22 gauge copper sheeting to hand make decorative shingles and used a standard office paper cutter. You might find a good used one at a surplus outlet that would work for corrugated metal providing the bends are not too tight. If you are going to cover the cut ends with angle anyway a little flattening of the cut won't affect the appearance.
M C Toyer wrote:les45 wrote:I recently had to cut about 500 24" long sections from a 1000' long roll of 16" wide 22 gauge copper sheeting to hand make decorative shingles and used a standard office paper cutter. You might find a good used one at a surplus outlet that would work for corrugated metal providing the bends are not too tight. If you are going to cover the cut ends with angle anyway a little flattening of the cut won't affect the appearance.
T
