a little confused as to the benefit of doubling up 3/4" plywood strips vs ...
Tony for the skeleton frame, to insulate that would you just cut foam board to fit in between the skeleton? And then skin in plywood or aluminum?tony.latham wrote:a little confused as to the benefit of doubling up 3/4" plywood strips vs ...
Doubling up 3/4" plywood strips? I'm not sure what you are referencing.
Building a skeleton from 3/4" plywood is an easy task. No joinery, other than lengthening which is simple with a 1/4" slot cutting router bit.
I gang cut them. Two at a time.
siena wrote:Tony for the skeleton frame, to insulate that would you just cut foam board to fit in between the skeleton? And then skin in plywood or aluminum?tony.latham wrote:a little confused as to the benefit of doubling up 3/4" plywood strips vs ...
Sent from my SM-G973U using Tapatalk
Is there a minimum width each "bone"...
tony.latham wrote:Is there a minimum width each "bone"...
I wish I knew that answer, but I have always thought that Tim's skeleton, aka noseoil, is all that is needed. He made a career of designing roof trusses so that should speak for itself.
This may explain my skeleton a bit since some of it is chunky:
The reason for the 4" along the outside edge in the galley is because 2" of it gets cut off for the hatch ends.
I don't know who this guy is but he sure looks cool in this video.
That'll show the hatch ends.
QQ; the benefits vs a full sheet are mainly for weight and if weight is not a concern it's fine to go with a full 3/4 sheet?
