Page 1 of 1
Australian Wood Fillers
Posted:
Thu Mar 05, 2020 10:27 pm
by MickinOz
Aussie members - what's a good exterior grade wood filler?
The skin will be structural ply glued and stapled.
Will be sealing with polyurethane (the mix), gluing and stapling the skin to the frame, then filling nail/staple holes, knots and splits, then painting.
Want to be able to get it from the hardware store.
I'm sorta conflicted - good 'ol no more gaps is flexible, sticks like sh!t to a blanket, is cheap and paints well.
Or there is builder's bog - polyester resin with various fillers.
Or is there something better?
Re: Australian Wood Fillers
Posted:
Thu Mar 05, 2020 10:51 pm
by edgeau
Are you bothered about blending into the wood or not?
For blending small areas I like keeping sawdust from my ply and mixing with PVA wood glue. Large areas spend the extra on Sikaflex. No more gaps is fine on stationary stuff indoors but is not right for the Teardrop. (I tried it)
Posted:
Thu Mar 05, 2020 11:18 pm
by MickinOz
I've been using the PVA with sanding dust, thought maybe I should use a proprietary product.
Dunno whether I'm doing it wrong, but If I use PVA and wood dust at a mixture wet enough to tool into a crack or hole, it sets almost clear.
Maybe if I wet the dust with water then added the PVA?
Posted:
Thu Mar 05, 2020 11:32 pm
by edgeau
I just put enough glue in to make it bread dough consistency
Posted:
Fri Mar 06, 2020 1:04 am
by MickinOz
Not sure on the "large areas spend the extra on Sikaflex" ?
Is there a sikaflex wood filler?
Posted:
Fri Mar 06, 2020 2:49 pm
by edgeau
MickinOz wrote:Not sure on the "large areas spend the extra on Sikaflex" ?
By large areas I meant a long join like where the wall meets floor or a knot where the center has come out. They don't market something specific as a wood filler. Sikaflex joint sealer comes in a couple of colours. There is a brown I have seen a couple of times but of course when I wanted it I could only get the beige.
Posted:
Fri Mar 06, 2020 3:06 pm
by MickinOz
Now I see.
I'm not having much need to fill joints, I'm pretty lucky with the range of tools I have for cutting them nice and accurate.
And the sika bond tech grip is amazing stuff, should the joint be a little less than perfect.
I have the Sika 292 for sealing seams as required, like where two sheets necessarily meet on the skin, and I may run around the floor to wall junction.
Even as I was thinking about using no more gaps, It never occurred to me to try the 292 for sealing up knots.
Good thing you are here to set me straight.
Posted:
Fri Mar 06, 2020 3:17 pm
by twisted lines
MickinOz wrote:I have the Sika 292 for sealing seams as required, like where two sheets necessarily meet on the skin, and I may run around the floor to wall junction.
I did run around the the floor to wall junction; Glued them on
Hope it docent hold as much water as my dump trailer.
