I would make your hatch a bit sturdier than shown in the instructions, but not as sturdy as mine, since it's kinda too heavy. Also, DON'T use 1/4" plywood under the aluminum. Use 1/8th. I used 1/4 and it sprung the hatch just enough to cause me to reshape the sides to match.
The way I fine tuned the sides to match the hatch was to use 1/2" U shaped channel aluminum over the 1/2" sides. I carefully noted where there was a bit of extra gap between the weather strip and the U channel, raised the channel a bit on the sides, and shot some caulk into the nearest screw hole in the face of the channel. When the caulk hardened, I put the screw back in, and the channel stayed put. You can see the shiny aluminum channel on the galley sides here.
