External mount access doors
Postby MJS613 » Thu Jun 11, 2020 12:05 pm
Hi All,
I am having troubles sourcing surface mount water tight access doors. I have attached a picture of the trailer for reference so you can see where i am trying to cover up. I can't use anything that needs to have holes cut to install due to the location of the storage areas. The 2 round ones at the back have PVC tubes running through them currently, the rectangular ones by the front could be either one door or 2 doors. I was hoping someone here would have a lead to some hatches that might fit the bill.
If not I would love some suggestions on how to build some sort of covers that I can use.
Thanks
MJS613
Images: 6
Re: External mount access doors
Postby GTS225 » Thu Jun 11, 2020 2:01 pm
MJS; Take a look in the marine market. I suggest you look at "deck plates" for the round holes, and there might be something out there for the rectangles. Deck plates can be had in white, black, or with a clear center insert. The center is a 1/4 turn remove/replace that allows access. They are not flush mount, but even with surface mounting, they are a rather low profile.
BTW; What size are the round holes?
Roger
GTS225
Postby MJS613 » Fri Jun 12, 2020 6:32 am
Hi Roger,
Ok I will take a look to see what I can find, the wholes are 4", I have thought about just getting the threaded ends for the PVC tubes and just have the screw on ends but would be nice if I don't have to have things sticking out the side.
Thanks,
Matt
MJS613
Images: 6
Postby swoody126 » Fri Jun 12, 2020 7:56 am
here's an example of marine deck hatches
https://www.duckworks.com/hatches-s/181.htm
they aren't cheap butt they are quite sound and seal well
sw
swoody126
Postby noseoil » Fri Jun 12, 2020 8:05 am
Just for future reference, it's easier to design around an existing door, hatch or lid than trying to match up something you do first to the marketplace. Better to find what you need & buy it, then build your design around an existing part. Just sayin' it won't help here, but it might help someone in the future...
137905
noseoil
Images: 669
Postby Tomterrific » Fri Jun 12, 2020 10:19 am
There are expanding rubber plugs in the plumbing dept. These would make the pvc water and air tight.
A while back there was a discussion about a side vent. It was a rectangle, not square, about the same size as your holes. Need to check size. One may even cover both tube holes. You would remove the center to work as a door.
Tt
Tomterrific
Postby troubleScottie » Fri Jun 12, 2020 11:11 am
Worth checking climateright
https://climateright.com/air-conditioning-heating/replacement-parts These are closures for their intake/outtakes. You might need both a flange and cap.
Michael Krolewski
Scottish Terrier Fancier
troubleScottie
Images: 16
Postby MJS613 » Wed Jun 16, 2021 8:40 pm
I know this is an old post by me but thought I would give an update. I couldn't find anything that would work so I ended up having some hatch doors made. Though I would share a pic.
MJS613
Images: 6
Postby Bezoar » Thu Jun 17, 2021 3:30 pm
looks like a tidy solution. Fits well with the black entry door.
What kind of paint did you use on the body?
Bezoar
Images: 37
Postby MJS613 » Thu Jun 17, 2021 8:04 pm
I used west system epoxy then sanded and coated with monstaliner roll on truck bed liner. Od green and the roof is cloudy haze and off white.
http://monstaliner.com
They have a Facebook page that's really active.
MJS613
Images: 6
