Floor build
Posted: Thu Nov 26, 2020 9:44 pm
Hello all. I am starting my first build. It will be the Benroy style. I have my frame built and am now ready to build and attach the flooring.
I will be insulating the trailer starting with the flooring.
After reading through the directions for the flooring in Step 3 I am a bit confused. It talks about using roof tar to coat the underside of the floor and then pressing the EPS into the wet tar. This is the part that confuses me.
Every video I have watched so far looks like the EPS is not in contact with the roofing tar.
The plans also talk about screwing the EPS into the recesses with 1 1/4' SS panhead crews and fender washers. Again something I have not seen in any of the videos.
The way I "think" it should go is 1/2" plywood, 1x2 frame glued down, 1 1/4" SS crews screwed through 1x2 into the plywood (THIS WILL BE THE BOTTOM SIDE), cover plywood side only with roofing tar, after dried attach to frame. glue EPS into cavities, another layer of 1/2" plywood, screw through plywood into 1x2, patch over screws with putty, sand, seal with urethane (THIS IS NOW THE TOP SIDE or the INSIDE THE TRAILER).
Does this sound correct?
Thanks for your assistance
