What's behind that wall?
Postby Tom&Shelly » Wed Feb 10, 2021 1:08 pm
I'm at the point in my build where I need to tie some things to the galley bulkhead I'd built several years ago, and it seems I deviated from the plans a little and forgot to properly note the changes. :oops:
164352
It turns out an old fashioned stud finder works wonderfully for this
164353
Probably obvious, but I don't remember it mentioned on TNTTT, so thought I would.
Our bulkhead is 1/8" Baltic birch over 3/4" plywood and blue foam. The stud finder measures electrical capacitance (I think). I clicked on it on an area I was confident was over foam, and the transitions to the plywood regions were crisp and clear.
172912 170466 173366
Tom&Shelly
Palladium Donating Member
Images: 2021
Re: What's behind that wall?
Postby tony.latham » Wed Feb 10, 2021 1:17 pm
Postby aggie79 » Fri Feb 12, 2021 4:55 pm
Wasn't my idea - somebody on this forum much wiser than I showed this technique - but I took wrote critical dimensions on wiring location and took pictures of framing before I placed the outer plywood skin.
