TimC wrote:Im assuming you mean teardrop builds... click on my signature threads (first and third build have some canvas (PMF) details. One is canvas on ply, the other is a work in progress canvas on foam.
Pmullen503 and ghcoe among others are experienced goalie builders and have a lot of useful PMF advice.
Tim
Tomterrific wrote:I painted the canvas on an old faded directors chair. I think it came out great. The fabric seems more substantial and a bit like leather. I have thought about using painted canvas over a frame work for some sort of structure. It seems one could make curves and folding shapes easily and light weight. You may want to look at skin on frame boats for construction hints. Sorry, I know of no homemade campers using this method.
Tt
John61CT wrote:For use in the cold, could (get a pro to) spray-foam from the inside, maybe upside down before attaching to the (rigid) floor.
Not just for thermal insulation,
no thermal bridging, tight vapour barrier envelope (all ventilation closely controlled)
But would add a lot of overall structural strength, resistance to travel/wind forces.
Very easy to patch & fix any dings.
If you were able to do a double-wall, then could use as the mold for **pourable** PU boat foam, very precise business that, just small layers / sections at a time to keep the expansion forces which get very high, under control.
No design limitations, free-form compound curves, super lightweight added strength. . .
Somewhere around here, I've got a nascent "wigwam / organic shapes trailer" thread
Pmullen503 wrote:I have a design with a lifting roof that's skin on frame that I'm going to start this spring. It will not be insulated save for a layer of Reflectix to reduce solar gain.
I plan to use dacron to cover it so I can shrink the fabric around the curved walls and roof. It is designed to be towable with a Prius so I shooting for under 500lbs.
I suppose one could spray insulation on the fabric and then upholster the inside to get a nice finished look.
Tomterrific wrote:As a mind experiment for a quick useful idea, I thought of a camper cover for protection with outdoor storage.
My camper sits outside in brutal Ohio weather. I keep it tarped but just wrapping the roof was not the best. Now I have a tarp stretched between a square frame of PVC pipe. This works well but doesn't look the best. I could use painted canvas that fit and matched the camper. PVC is bendable for a pretty curved storage roof. Yet another project.
Tt
Tomterrific wrote:I really don't need insulation. We have the top vent cracked all the time. At night, when we are in the camper, there is no sun and vents are open. Besides, bright white paint seemed to block the suns heat as much as the insulation. In cooler weather we have an electric blanket that we need to keep on low or off. I do have the ceiling insulated with foam panels but question if they are necessary for summer camping. Then there was this one time when the temp dropped, the wind blew and we were in a non electric camp site last January.
I think insulation goes well with a different design than fabric over frame. One of the coolest design elements is seeing the frame inside.
Tt
