Using magnets to seal a flimsy door?
Postby Betonhaus » Thu Apr 15, 2021 6:08 pm
Could you get by with a lighter and less ridgid door if you put some strong magnets int he door frame to keep it sealed when closed?
Betonhaus
Re: Using magnets to seal a flimsy door?
Postby Tomterrific » Sun Apr 18, 2021 9:59 am
I can't conceive of a door lighter and more flimsy than mine. It is made with Revolution ply and has cheap 1x3 on the edges. just a simple screen door latch secures it. The door is too stiff for magnets to pull a warp out but could help keep from warping over time. I did use little magnets to secure a screen curtain so we could be inside with the door open.
Could you give a description of your door construction?
Tt
Tomterrific
Postby Betonhaus » Sun Jan 23, 2022 4:37 pm
Tomterrific wrote:I can't conceive of a door lighter and more flimsy than mine. It is made with Revolution ply and has cheap 1x3 on the edges. just a simple screen door latch secures it. The door is too stiff for magnets to pull a warp out but could help keep from warping over time. I did use little magnets to secure a screen curtain so we could be inside with the door open.
Tt
Thanks. I don't have a door construction planned yet but I'm thinking of something like a hollowed out piece of plywood filled with foam and wrapped in PMF.
Betonhaus
Postby tony.latham » Sun Jan 23, 2022 8:37 pm
Magnets won't keep water or dust out. It has to be a rubber seal of some type.
:thinking:
Postby saywhatthat » Sun Jan 23, 2022 10:22 pm
Tony on your door jamb it looks like you're using two different type of seals?
Il suffit de le faire
viewtopic.php?f=50&t=73945
saywhatthat
Images: 135
Postby tony.latham » Sun Jan 23, 2022 10:59 pm
saywhatthat wrote:Tony on your door jamb it looks like you're using two different type of seals?
The one on the left is cosmetic to fill the door gap.
This is the real deal:
