I would like to cut down an RV door for my teardrop. I will have doors on both curbside and road side. RV doors are set up for the curbside and I see no problem.
I have not found any roadside doors. Ideas on what to do about the roadside?
AKRefugee wrote:I would like to cut down an RV door for my teardrop. I will have doors on both curbside and road side. RV doors are set up for the curbside and I see no problem.
Woodbutcher wrote:AKRefugee wrote:I would like to cut down an RV door for my teardrop. I will have doors on both curbside and road side. RV doors are set up for the curbside and I see no problem.
I do not understand the need for a different door on the roadside. Every trailer I have seen that has a roadside door uses the same door for both sides. I'm curious why you want a different door on the roadside. You may need to make your doors to get what you want.
